[GRASS-dev] [GRASS GIS] #3191: coordinate reference system issue when exporting to Rasterlite
trac at osgeo.org
Mon Oct 24 10:20:42 PDT 2016
Reporter: vincent | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.6
Component: Raster | Version: unspecified
Resolution: | Keywords: gdal export, Rasterlite
CPU: Unspecified | Platform: Unspecified
Comment (by hellik):
Replying to [comment:2 vincent]:
> Yes, I've come to the same observation so far, but I don't know enough
about how GRASS parses projection info to gdal; sorry for this rather
naive question but in the case of GTiff driver why then is there no need
to worry about coordinate reference system information for it to work?
> Well, if you all prefer, we can close the ticket.
taken from the [https://lists.osgeo.org/pipermail/gdal-
dev/2016-October/045359.html GDAL ML]
> is this intentional that there is no srs by a simple gdal_translate of a
> geotiff to a Rasterlite db?
From what I can see the driver doesn't handle adding a new entry in the
spatial_ref_sys table if there's no AUTHORITY node, such as in your use
case.
From what I can see, it also probably doesn't properly support creating
entries in spatial_ref_sys with Spatialite 4 layout (the driver has been
likely developped during Spatialite 3 era)
It is "intentional" in the meaning that this wasn't implemented, but could
potentially be added. Could be worth a ticket in Trac.
> maybe there is some other command line option related to Rasterlite db
> which I'm missing?
No, the workaround is the one you found. Make sure a EPSG code is attached
to
the input dataset, or assign it explictly
I think this ticket can be closed; but I'll open another one for the last
issue mentioned above.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3191#comment:4>
