W dniu 24.10.2016 o 14:06, Vincent Bain pisze: > Unfortunately this is not a valid lco... > > OK, it is not really a critical issue as we can easily solve it whether > via gdal_translate or via a simple sql update, Maybe `gdal_edit.py -a_srs' will be the simplest workaround? Maciek -- Maciej Sieczka http://www.sieczka.org
