[GRASS-dev] r.out.gdal and Rasterlite driver
Even Rouault even.rouault at spatialys.com
Tue Oct 25 03:08:19 PDT 2016
Le mardi 25 octobre 2016 12:02:01, Vincent Bain a écrit :
> Hi Maciek,
> thanks for your suggestion. In fact, the script runs without error or
> warning but it does not change anything :
>         gdalinfo Rasterlite:my_db.sqlite,table=my_raster
>             AUTHORITY["EPSG","54321"]]
>         gdal_edit.py -a_srs EPSG:12345 \
Yes, the SetProjection() method needed to change the SRS on an existing
dataset isn't implemented in the GDAL Rasterlite driver.
http://www.spatialys.com
