[GRASS-dev] [GRASS GIS] #3184: v.vect.stats: errors in counts and statistics
trac at osgeo.org
Tue Oct 25 12:10:28 PDT 2016
Reporter: veroandreo | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.2.0
Component: Vector | Version: svn-trunk
Resolution: fixed | Keywords: v.vect.stats
CPU: x86-64 | Platform: Linux
Changes (by mmetz):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"69722" 69722]:
#!CommitTicketReference repository="" revision="69722"
v.vect.stats: fix #3184, also remove the erroneous 'half' parameter
Ticket URL: <https://trac.osgeo.org/grass/ticket/3184#comment:16>
