[GRASS-dev] [GRASS GIS] #3184: v.vect.stats: errors in counts and statistics
trac at osgeo.org
Tue Oct 25 12:17:55 PDT 2016
Reporter: veroandreo | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.2.0
Component: Vector | Version: svn-trunk
Resolution: fixed | Keywords: v.vect.stats
CPU: x86-64 | Platform: Linux
Comment (by mmetz):
Replying to [comment:15 mlennert]:
> Replying to [comment:14 mmetz]:
> > Replying to [comment:13 veroandreo]:
> > > Replying to [comment:12 mmetz]:
> > > > I have uploaded a patch (v_vect_stats_unique_cats_no_half.diff)
that correctly removes duplicate cats (similar to
v_vect_stats_unique_cats.2.diff) and additionally eliminates the usage of
half (adding 0.5 to the result). This half makes only sense if the result
is to be converted to integer and if the result is a positive number. The
result is always floating point, therefore adding 0.5 causes wrong
results.
> > > Thanks Markus! I applied the patch and tested with Moritz's test
data and examples, and also with my own data. Counts are fine and also
stats :)
> > This is a bugfix and should be backported to the G7 release branches.
Too late for 7.2?
> I would say no. We're just about to release RC1, so bugfixing is more
than welcome. In addition, the fix will not change anything else outside
of v.vect.stats and seems important enough to include.
OK, applied to trunk, relbr72, and relbr70 in r69722-4.
> I guess we would need some basic automatic tests to make sure that it
doesn't modify other expected behavior ? ;-)
I would wait for any new errors in the test suite. If other expected
behaviour is no longer met, that expectation was wrong.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3184#comment:19>
