[GRASS-dev] broken winGRASS
Helmut Kudrnovsky hellik at web.de
Thu Sep 1 00:06:21 PDT 2016
hi,
it seems  the daily winGRASS (standalone and OSGeo4W) are broken:
see https://wingrass.fsv.cvut.cz/grass73/x86_64/logs/log-r69289-73/error.log
GRASS GIS 7.3.svn r69289 compilation log
Started compilation: Mon Aug 29 03:54:24     2016
Errors in:
/c/msys64/usr/src/grass_trunk/raster/r.in.lidar
/c/msys64/usr/src/grass_trunk/raster3d/r3.in.lidar
/c/msys64/usr/src/grass_trunk/vector/v.out.lidar
/c/msys64/usr/src/grass_trunk/vector/v.in.lidar
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Mon Aug 29 04:18:03     2016
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/broken-winGRASS-tp5283441.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
