[GRASS-dev] Delete r.le.* now?
Moritz Lennert mlennert at club.worldonline.be
Thu Sep 1 01:13:02 PDT 2016
On 01/09/16 08:03, Luca Delucchi wrote:
> On 1 September 2016 at 03:34, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>> Hi,
> Hi,
>> in November 2014, r.le suite was moved to Addons as being functional and
>> potentially still useful although there is r.li [1, 2]. There were some
>> improvements in r.li around that time [3] and some small improvements in
>> g.gui.rlisetup since than [4].
>> However, more importantly, the r.le modules can't be currently compiled.
>> r.le.setup needs vask library which was removed and the other modules have
>> various compilation issues (which would be fixable).
>> I suggest identifying what is missing in r.li from r.le and opening tickets
>> for it. Then it seems that it is time to remove r.le.* from addons, so it is
>> clear that they don't need to be maintained.
>> In case somebody want to use r.le, the modules are still accessible in 6.4
>> if I understand it correctly.
> +1 for remove r.le modules
+1
Moritz
