[GRASS-dev] How to: if undefined, set to NULL?
Mon Sep 5 08:46:31 PDT 2016
Vaclav Petras wrote:
> > Updated in sandbox, see: https://trac.osgeo.org/grass/changeset/69365
> > Is it though correct?
> I was not looking at the logic but
> if (hue == -1.0) {
> is not safe. Although it will probably work most of the time if you set it
> to the exactly same value (`hue = -1;`),
There's no "probably" about it. If you execute "hue = -1;", a
subsequent "if (hue == -1)" comparison *will* succeed.
Rounding error only occurs when the correct result isn't exactly
representable, which isn't the case here. It doesn't occur randomly.
