[GRASS-dev] [GRASS GIS] #3027: i.atcorr's create_iwave.py broken
trac at osgeo.org
Tue Sep 6 05:51:56 PDT 2016
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Imagery | Version: svn-releasebranch70
Resolution: | Keywords: i.atcorr
CPU: x86-64 | Platform: All
Comment (by neteler):
Replying to [comment:5 nikosa]:
> Patch updated to handle, now hopefully, all cases -- whether the *input*
step in the wavelength slots is less, equal or greater than the
*hardcoded* step `2.5` for the interpolation function.
Thanks for that. Unfortunately it still fails:
python create_iwave.py sensors_csv/landsat_8.csv
Getting sensor name from csv file: landsat_8
Number of bands found: 9
File "create_iwave.py", line 267, in <module>
main()
File "create_iwave.py", line 254, in main
write_cpp(bands, values, sensor, os.path.dirname(inputfile))
File "create_iwave.py", line 173, in write_cpp
fi, li = interpolate_band(values[:,[0,b+1]])
File "create_iwave.py", line 108, in interpolate_band
filter_f = f(np.arange(start, stop, step))
File "/usr/lib/python2.7/dist-packages/scipy/interpolate/polyint.py",
line 54, in __call__
y = self._evaluate(x)
packages/scipy/interpolate/interpolate.py", line 448, in _evaluate
out_of_bounds = self._check_bounds(x_new)
packages/scipy/interpolate/interpolate.py", line 478, in _check_bounds
raise ValueError("A value in x_new is above the interpolation "
ValueError: A value in x_new is above the interpolation range.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3027#comment:7>
