[GRASS-dev] Raster data compression confusion: identical CELL file size
Yann Chemin yann.chemin at gmail.com
Tue Sep 6 07:39:52 PDT 2016
On 6 September 2016 at 15:23, Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> On Tue, Sep 6, 2016 at 1:44 PM, Markus Neteler <neteler at osgeo.org> wrote:
> > Hi,
> > since my local drive was filled up again :) I checked raster how data are
> > currently compressed in GRASS GIS 7.2.svn.
> > According to
> > https://grass.osgeo.org/grass72/manuals/r.compress.
> html#used-compression-algorithms
> > all maps are DEFLATE compressed by default:
> > "Raster maps are by default ZLIB compressed.
> > Floating point (FCELL, DCELL) raster maps never use RLE compression; they
> > are either compressed with ZLIB, LZ4, BZIP2 or are uncompressed.
> > Ehm, now how *are* FCELL, DCELL compressed by default? Not quite clear to
> > me! This document needs improvements.
> The manual says, as you cited:
> "Raster maps are by default ZLIB compressed."
> What exactly is unclear about this? Should it say "All raster maps ..." ?
> > Reality check with Sentinel-2 data (3 different bands, same regional
> > extent):
> > GRASS 7.2.svn (utm37n):~ > r.info -r s2_20151225_B02_10m
> > min=0
> > max=22937
> > GRASS 7.2.svn (utm37n):~ > r.info -r s2_20151225_B04_10m
> > min=0
> > max=18849
> > GRASS 7.2.svn (utm37n):~ > r.info -r s2_20151225_B8A_20m
> > min=0
> > max=17210
> > GRASS 7.2.svn (utm37n):~ >:~ > r.compress s2_20151225_B02_10m -p
> > <s2_20151225_B02_10m> is compressed (method 2: ZLIB). Data type:
> > CELL
> > GRASS 7.2.svn (utm37n):~ >:~ > r.compress s2_20151225_B04_10m -p
> > <s2_20151225_B04_10m> is compressed (method 2: ZLIB). Data type:
> > CELL
> > GRASS 7.2.svn (utm37n):~ >:~ > r.compress s2_20151225_B8A_20m -p
> > <s2_20151225_B8A_20m> is compressed (method 2: ZLIB). Data type:
> > CELL
> > So far so nice. Now the suprising part, while the channels are not
> identical
> > (obviously, since covering different spectral parts), the map sizes are
> > identical!
> > GRASS 7.2.svn (utm37n):~ > ls -la
> > -rw-r--r--  1 neteler neteler 2539235691 Jun 14 17:14 s2_20151225_B02_10m
> > -rw-r--r--  1 neteler neteler 2539235691 Jun 14 17:19 s2_20151225_B03_10m
> > -rw-r--r--  1 neteler neteler 2539235691 Jun 14 17:25 s2_20151225_B04_10m
> > -rw-r--r--  1 neteler neteler  634878630 Jun 14 20:36 s2_20151225_B05_20m
> > -rw-r--r--  1 neteler neteler  634878630 Jun 14 20:37 s2_20151225_B06_20m
> > -rw-r--r--  1 neteler neteler  634878630 Jun 14 20:39 s2_20151225_B07_20m
> > -rw-r--r--  1 neteler neteler  634878630 Jun 14 20:40 s2_20151225_B11_20m
> > -rw-r--r--  1 neteler neteler  634878630 Jun 14 20:42 s2_20151225_B12_20m
> > -rw-r--r--  1 neteler neteler  634878630 Jun 14 20:43 s2_20151225_B8A_20m
> > I would expect different sizes, compression can hardly lead to identical
> > file sizes.
> The default ZLIB compression level was invalid, causing ZLIB to not
> compress at all. Fixed in r69387,8.
> Markus M
> > Next test: gzip the file
> > GRASS 7.2.svn (utm37n):~/grassdata/utm37n/PERMANENT/cell > ls -la
> > s2_20151225_B03_10m
> > -rw-r--r-- 1 mneteler mneteler 2539235691 Jun 14 17:19
> s2_20151225_B03_10m
> > GRASS 7.2.svn (utm37n):~/grassdata/utm37n/PERMANENT/cell > gzip
> > s2_20151225_B03_10m
> > s2_20151225_B03_10m.gz
> > -rw-r--r-- 1 mneteler mneteler 1456248453 Jun 14 17:19
> > R
> >> 1456248453/2539235691
> > [1] 0.5734987
> > Quite smaller! So I am not at all convinced that these CELL files are
> > currently ZLIB compressed.
> Compressing a whole file instead of compressing each row separately
> (GRASS reads and writes raster data row by row) can lead to higher
> compression ratios.
This brings to a long time amount of discussions about parallelization
speed-ups of raster functions being limited by the row-based I/O of GRASS.
Maybe we should look into this for GRASS8...
> > From this ticket I would expect something else:
> > https://trac.osgeo.org/grass/ticket/2349
> > Ah, and no specific environment variables are set:
> > GRASS 7.2.svn (utm37n):~ > echo $GRASS_<tab>
> > $GRASS_ADDON_BASE   $GRASS_GNUPLOT    $GRASS_HTML_BROWSER  $GRASS_PAGER
> > $GRASS_PROJSHARE    $GRASS_PYTHON     $GRASS_VERSION
> > A bug?
> > Markus
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-dev
Yann Chemin
Skype/FB: yann.chemin
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160906/55889b7f/attachment-0001.html>
