[GRASS-dev] [GRASS GIS] #3144: i.segment.hierarchical: RuntimeError: Execution of subprocesses was not successful
GRASS GIS trac at osgeo.org
Tue Sep 6 10:27:40 PDT 2016
successful
 Reporter:  mlennert                           |      Owner:  grass-dev@…
     Type:  defect                             |     Status:  new
 Priority:  normal                             |  Milestone:
Component:  Addons                             |    Version:  unspecified
 Keywords:  i.segment.hierarchical GridModule  |        CPU:  Unspecified
 Platform:  Unspecified                        |
 I just can't get i.segment.hierarchical to run in parallel processing with
 the GridModule:
 i.group ls_ms
 in=lsat7_2002_10 at PERMANENT,lsat7_2002_30 at PERMANENT,lsat7_2002_20 at PERMANENT,lsat7_2002_40 at PERMANENT,lsat7_2002_50 at PERMANENT,lsat7_2002_70 at PERMANENT
 g.region rast=lsat7_2002_70 at PERMANENT
 i.segment.hierarchical ls_ms threshold=0.1 output=ls_ms_seg width=200
 height=200 overlap=10
 gives me
   File "/home/mlennert/.grass7/addons/scripts/i.segment.hierarchical",
 line 252, in <module>
     SEG.run()
   File "/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-linux-
 gnu/etc/python/grass/pygrass/modules/grid/grid.py", line 553, in run
     raise RuntimeError(_("Execution of subprocesses was not successful"))
 I don't really know how to start debugging this. Could someone point me in
 the right direction ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3144>
