[GRASS-dev] [GRASS GIS] #2902: i.segment.hierarchical: Execution of subprocesses was not successful
Moritz Lennert
mlennert at club.worldonline.be
Wed Sep 7 13:00:08 PDT 2016
On 07/09/16 12:07, Markus Neteler wrote:
> On Wed, Sep 7, 2016 at 11:36 AM, GRASS GIS <trac at osgeo.org
> successful
>> Setting this to True led me to a
>> bug in pygrass which still had a call to type='rast' instead of
>> type='raster'. Corrected in trunk in r69392.
> There appear to be some more to be fixed but I cannot say which ones
> are false positives in this sloppy grep search (sorry for the HTML
> formatting to preserve line breaks):
> find . -type f | xargs grep "'rast'" | grep -v svn/pristine
> ./scripts/r.shade/r.shade.py <http://r.shade.py>:
> type='rast', name=maps)
> ./scripts/r.grow/r.grow.py
> <http://r.grow.py>: type='rast', name=map)
> ./gui/wxpython/psmap/dialogs.py: {'rast': self.currRaster,
> 'type': rasterType})
> ./gui/wxpython/psmap/dialogs.py: {'rast': currRaster, 'type':
> str(rasterType)})
> ./gui/wxpython/lmgr/layertree.py: module = 'rast'
> ./lib/python/gunittest/gutils.py: if type == 'rast' or type == 'raster':
> ./lib/python/pygrass/raster/abstract.py: utils.remove(self.name
> <http://self.name>, 'rast')
> utils.rename(self.name <http://self.name>, newname, 'rast')
> ./lib/python/pygrass/modules/grid/grid.py: for r in
> findmaps('rast', location=dst[1], gisdbase=dst[2])]
> ./lib/python/pygrass/modules/interface/testsuite/test_parameter.py:
> param = Parameter(diz=dict(name='rast', required='yes',
> ./lib/python/temporal/temporal_algebra.py: maptype='rast',
> mapclass=RasterDataset,
> ./lib/python/script/core.py: if element == 'raster' or element == 'rast':
> find . -type f | xargs grep "'vect'" | grep -v svn/pristine
> ./scripts/v.db.reconnect.all/v.db.reconnect.all.py
> <http://v.db.reconnect.all.py>: vectors =
> gscript.list_grouped('vect')[mapset]
> ./scripts/v.build.all/v.build.all.py <http://v.build.all.py>: vectors
> = grass.list_grouped('vect')[mapset]
> ./gui/wxpython/lmgr/layertree.py: module = 'vect'
> ./lib/python/gunittest/gutils.py: elif type == 'vect':
> ./lib/python/pygrass/utils.py: >>> remove('test_vect_2','vect')
> ./lib/python/pygrass/vector/table.py: >>>
> copy(test_vector_name,'mycensus','vect')
> ./lib/python/pygrass/vector/table.py: >>> remove('mycensus', 'vect')
> ./lib/python/pygrass/vector/table.py: >>> remove('mycensus','vect')
> ./lib/python/pygrass/vector/abstract.py:
> utils.rename(self.name <http://self.name>, newname, 'vect')
> ./lib/python/pygrass/vector/abstract.py: utils.remove(self.name
> <http://self.name>, 'vect')
> ./lib/python/pygrass/vector/__init__.py: >>>
> copy(test_vector_name,'mytest_vect','vect')
> remove('mytest_vect', 'vect')
> ./lib/python/script/core.py: >>> list_grouped('vect',
> pattern='*roads*')['PERMANENT']
> ./lib/python/script/db.py: vects = list_strings('vect')
> ... anyone willing to go through and fix the few true Python issues?
> Those should then also be backported to 7.2.svn.
I'd rather have some of the real pygrass and script library experts look
at this, but AFAICS, none of these (except for grid.py call to findmaps
(but which I already fixed in trunk) actually cause any trouble. I think
it was the specfic findmaps function call that uses a ctypes call that
caused the issue.
But maybe someone else could confirm or infirm this ?
Moritz
