[GRASS-dev] [GRASS GIS] #3149: Adding database information to v.info metadata output
trac at osgeo.org
Sun Sep 11 12:43:13 PDT 2016
Reporter: huhabla | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.2.0
Component: Default | Version: svn-releasebranch72
Resolution: | Keywords: vector, info, v.info
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [comment:5 huhabla]:
> Replying to [comment:4 mlennert]:
> > Replying to [comment:3 huhabla]:
> > >The output of v.db.connect -g is not well
> > >designed for parsing, neither for bash
> > >nor for the python-grass-script library.
> > Then let us improve that :-)
> I guess there was a specific reason behind the implementation of the
"-g" flag in v.db.connect in the way it is. I fear to break existing
functionality when modifying v.db.connect "-g" flag output.
> Since we do not have enough module tests, it would be hard to figure out
what will break in existing modules, in examples and documented work flows
and even more harder to figure out if extensions will break.
The output of v.db.connect -g prints all connections for all layers,
therefore the typical key=value approach does not work well, instead you
need to tokenize each output line. Also, the python grass script library
uses the output of v.db.connect -g e.g. in vector_db which works just
fine, also for multiple connections.
> IMHO the database connection is vector map metadata that should be
available within v.info, so the user does not have to search for another
module to get this information. The default settings of vector layer
database management usually does not require the user to use v.db.connect,
hence its capabilities is mostly unknown to the user.
> I think the less invasive solution is to modify v.info, especially since
i have already implemented 6 tests to verify the functionality. ;)
Please make sure that your patch for v.info only prints connection
parameters if a single, valid layer is selected because your approach can
not handle multiple connections.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3149#comment:8>
