[GRASS-dev] [GRASS GIS] #1105: un-red the trac theme
GRASS GIS trac at osgeo.org
Sun Sep 11 18:56:48 PDT 2016
  Reporter:  hamish       |      Owner:  grass-dev@…
      Type:  task         |     Status:  new
  Priority:  minor        |  Milestone:  Website
 Component:  Website      |    Version:
Resolution:               |   Keywords:  trac theme
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by nikosa):
 Replying to [comment:6 neteler]:
 > I wonder where to insert style changes:
 > `/var/www/trac/grass/templates/site_css.cs`
 > is empty. No other css file on the server...
 See
 https://trac.edgewall.org/wiki/TracInterfaceCustomization#SiteAppearance
 Also, useful notes lower down in the
 https://trac.edgewall.org/wiki/TracInterfaceCustomization#ProjectTemplates
 section:
  ''The appearance of each individual Trac environment, ie instance of a
 project, can be customized independently of other projects, even those
 hosted on the same server. The recommended way is to use a `site.html`
 template whenever possible, see
 [https://trac.edgewall.org/wiki/TracInterfaceCustomization#SiteAppearance
 #SiteAppearance]. '''Using `site.html` means changes are made to the
 original templates as they are rendered, and you should not normally need
 to redo modifications whenever Trac is upgraded.''' If you do make a copy
 of `theme.html` or any other Trac template, you need to migrate your
 modifiations to the newer version. If not, new Trac features or bug fixes
 may not work as expected.''
Ticket URL: <https://trac.osgeo.org/grass/ticket/1105#comment:7>
