[GRASS-dev] Cannot move temp file with os.rename change
Markus Neteler
neteler at osgeo.org
Mon Sep 12 05:08:18 PDT 2016
Re - #3148: d.wms cannot move temp file with os.rename
There are a few more places in which os.rename is used:
find . -type f | xargs grep "os.rename" | grep -v svn/pristine
./scripts/r.in.srtm/r.in.srtm.py: os.rename(hgtfile, bilfile)
./gui/wxpython/gis_set.py:
os.rename(os.path.join(self.gisdbase, location, mapset),
os.rename(os.path.join(self.gisdbase, location),
./gui/wxpython/rlisetup/frame.py:
os.rename(os.path.join(self.rlipath, confile), newname)
./lib/python/gunittest/reporters.py: os.rename(tmp_file_path, file_path)
./man/build_html.py: os.rename(temp, name)
./man/build_rest.py: os.rename(temp, name)
... any others to be updated to use shutil.move() as done here
https://trac.osgeo.org/grass/changeset/69429
Markus
