[GRASS-dev] v.in.pygbif addon: Manual does not build
Vaclav Petras
wenzeslaus at gmail.com
Tue Sep 13 08:20:23 PDT 2016
On Tue, Sep 13, 2016 at 11:15 AM, Markus Neteler <neteler at osgeo.org> wrote:
> root at osgeo6:/home/neteler# pip install pygbif
> bash: pip: command not found
I don't think it's necessary to install all addon dependencies on the build
server for Python where it is easy to work around it. Moreover the code is
useful also when user installs the module not having the dependencies (then
it installs, shows the GUI but gives a proper error message as opposed to
failing somewhere in between).
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160913/1937374c/attachment.html>
