[GRASS-dev] [GRASS GIS] #3156: Cannot export GRASS raster map using r.out.png (crashes on windows)
trac at osgeo.org
Wed Sep 14 09:52:13 PDT 2016
Reporter: spawley | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Raster | Version: 7.0.4
Keywords: | CPU: x86-64
Platform: MSWindows 7 |
I'm having a problem with the r.out.png module on windows. I have tried
using the standalone grass 7.0.4 (64), as well as OSGeo4W 7.04 and 7.3 64
bit versions. Any attempt to export a GRASS raster using r.out.png causes
a 'GRASS 7 has stopped working' error.This also affects the Pygrass
ability to display GRASS rasterrow objects, for instance as part of
jupyter notebook. The output is in writable directory with a correct path.
The module creates an output png file, but then crashes, leaving the png
file empty.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3156>
