[GRASS-dev] [GRASS GIS] #2055: r.in.gdal lacks flag "-r Limit import to the current region"
trac at osgeo.org
Thu Sep 15 12:17:52 PDT 2016
Reporter: neteler | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.2.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.in.gdal, r.import
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [comment:14 martinl]:
> Replying to [comment:13 neteler]:
> > The solution would be "lazy cutting", that is not cutting sharp to the
boundary but allow for a small "extra". Essentially, like v.in.ogr
behaves. Resampling is definitely undesired since we usually import as-is
in r.in.gdal.
> > Lines to look at:
https://trac.osgeo.org/grass/browser/grass/trunk/raster/r.in.gdal/main.c#L359
> Please try out attachment:r_in_gdal_2055.diff.
Tests are missing:
* if the current region and the input raster do not overlap, fatal error,
but special care for !Lat/Lon locations
* if the current region and the input raster overlap only partially,
adjust the current region to avoid importing all-NULL rows/columns
For !Lat/Lon, some kind of window mapping similar to
`Rast__create_window_mapping()` in trunk/lib/raster/window_map.c would
help. Otherwise, a current region with EW extents of e.g. -20,-10 and an
input raster with EW extents of 0,360 will result in all NULL cells even
though the current region is covered by the input raster.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2055#comment:16>
