[GRASS-dev] ubuntu gis policy
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Fri Sep 16 04:12:32 PDT 2016
Hei Martin,
Do you have any chance to influence the naming of the PPAs?
As recently also discussed on the QGIS mailinglist, packages from a repository named "unstable" can get blocked by system administrators (who not necessarily will take the time to try to understand what is behind all applications), regardless if I as a user tell them that "unstable" actually means "current release"...
Would be nice to have a more admin-friendly name there...
Cheers
Stefan
-----Original Message-----
From: grass-dev [mailto:grass-dev-bounces at lists.osgeo.org] On Behalf Of Martin Landa
Sent: 16. september 2016 13:03
To: GRASS users list <grass-user at lists.osgeo.org>; GRASS developers list <grass-dev at lists.osgeo.org>
Subject: [GRASS-dev] ubuntu gis policy
Hi all,
recently ubuntugis maintainers changed their policy. This means that currently is used this workflow:
OSGeoLive nightly --> UbuntuGIS Testing --> UbuntuGIS Unstable --> UbuntuGIS Stable
What does it means for GRASS?
1) experimental packages (like Release Candidates) are uploaded to Testing PPA [1]
2) final version packages are uploaded to Testing and Unstable [2]
3) Stable PPA can contain older version [3]
For user who want to help with testing experimental packages: please use Testing PPA otherwise use Unstable (if you prefer up-to-date
version) or Stable PPA (you prefer stability - slightly older versions).
Martin
[1] https://launchpad.net/~ubuntugis/+archive/ubuntu/ubuntugis-testing
[2] https://launchpad.net/~ubuntugis/+archive/ubuntu/ubuntugis-unstable
[3] https://launchpad.net/~ubuntugis/+archive/ubuntu/ppa
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
grass-dev mailing list
http://lists.osgeo.org/mailman/listinfo/grass-dev
