[GRASS-dev] v.in.pygbif addon: Manual does not build
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Sun Sep 18 14:29:03 PDT 2016
Thanks Helmut, Vaclav, Markus for your support.
Should be fixed now (by moving the import to "dev main()").
I would have liked to do it earlier but we had a failure on the server where I had the code...
Kind regards,
Stefan
-----Original Message-----
From: grass-dev [mailto:grass-dev-bounces at lists.osgeo.org] On Behalf Of Helmut Kudrnovsky
Sent: 13. september 2016 17:21
To: grass-dev at lists.osgeo.org
Subject: Re: [GRASS-dev] v.in.pygbif addon: Manual does not build
Markus Neteler wrote
> On Tue, Sep 13, 2016 at 4:52 PM, Helmut Kudrnovsky <
> hellik@
> > wrote:
>>>Thanks for your swift reply!
>>>In v.in.pygbif the import of pygbif is also done in a try-except
statement.
>>>Maybe the difference is that pyspatialite is installed on the build
system,
>> while pygbif is (naturally) not >(yet)?
> Exactly...
> root at osgeo6:/home/neteler# pip install pygbif
> bash: pip: command not found
> How to get pip into this Debian box? (keeping the other 10 virtual
> sites on the system intact) Will be easy but I am more RPM oriented...
apt-get install python-pip?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/v-in-pygbif-addon-Manual-does-not-build-tp5285571p5285594.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
grass-dev mailing list
http://lists.osgeo.org/mailman/listinfo/grass-dev
