[GRASS-dev] C code examples?
Rainer M Krug Rainer at krugs.de
Mon Sep 19 02:02:55 PDT 2016
Nikos Alexandris <nik at nikosalexandris.net> writes:
> I am reading the code of `r.example`. This is good code because it
> explains in a clean way what is, does and why so.
> Is there more such "good" code?  Would you have a local copy of your C module
> rich in comments, not submitted, I'd be very happy to get hands on it.
Hi
Did you get any feedback? I will be in the same position son, and I am
also looking at good examples of modules in C and possibly python as
well?
Might be worth adding a wiki page with these examples and explanations?
Rainer
> Thank you, Nikos
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Rainer M. Krug
email: Rainer<at>krugs<dot>de
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160919/36136408/attachment.sig>
