[GRASS-dev] Working with TGIS without starting GRASS explicitly
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Wed Sep 21 23:36:01 PDT 2016
Hei Laurent,
What about using the --exec magic from > GRASS 7.2?
https://grass.osgeo.org/grass72/manuals/grass7.html#batch-jobs-with-the-exec-interface
(or the GRASS_BATCH_JOB solution)?
Cheers
Stefan
-----Original Message-----
From: grass-dev [mailto:grass-dev-bounces at lists.osgeo.org] On Behalf Of Laurent C.
Sent: 22. september 2016 02:47
To: Sören Gebbert <soerengebbert at googlemail.com>
Cc: GRASS developers list <grass-dev at lists.osgeo.org>
Subject: Re: [GRASS-dev] Working with TGIS without starting GRASS explicitly
Hello all,
I've ran into another related issue.
One of the goal of running the software outside of GRASS shell is to batch process simulations in various Locations/mapsets.
I set the GRASS session for each case. The simulation works well for the first case.
However when starting the second case, tgis.init() fails with the following error:
ERROR: Unable to execute sql statement. There is no temporal database connection defined for mapset <hull>
The mapset and location are properly set.
If this case is run first, it works well and it's the second one that fail.
Running t.connect -c between two cases does not solve the problem.
Actually, t.connect -p shows the correct connection parameters, but
tgis.init() still fails.
Regards,
Laurent
2016-09-21 18:27 GMT-05:00 Laurent C. <lrntct at gmail.com>:
> Hi Sören,
> Setting LD_LIBRARY_PATH is working, thanks. But it cannot be set at
> run-time, which is not very user-friendly.
> I guess this issue is related to the ticket 2424 [1].
> I managed to get it work at run-time by restarting the program with
> sys.execv() after setting the path [2], but I find it a bit ugly and
> quite verbose to be multi-platform.
> It would be great if an easier option was possible.
> Regards,
> Laurent
> [1] https://trac.osgeo.org/grass/ticket/2424
> [2]
> http://stackoverflow.com/questions/6543847/setting-ld-library-path-fro
> m-inside-python
> 2016-09-21 15:40 GMT-05:00 Sören Gebbert <soerengebbert at googlemail.com>:
>> Hi,
>> i think you have to put the GRASS libraries into your LD_LIBRARY_PATH
>> so that the python wrapper can access them.
>> Best regards
>> Soeren
>> 2016-09-21 20:37 GMT+02:00 Laurent C. <lrntct at gmail.com>:
>>> Hello all,
>>> I'm trying to adapt a python module in order for it to be run
>>> outside of GRASS.
>>> I followed the instructions from the wiki and
>>> lib/python/script/setup.py
>>> gsetup.init() run without error and I can list maps like in the example.
>>> However, when I try to import the temporal module, I receive this error:
>>> import grass.temporal as tgis
>>>   File "/usr/lib/grass70/etc/python/grass/temporal/__init__.py",
>>> line 1, in <module>
>>>     from core import *
>>>   File "/usr/lib/grass70/etc/python/grass/temporal/core.py", line
>>> 38, in <module>
>>>     from c_libraries_interface import *
>>>   File
>>> "/usr/lib/grass70/etc/python/grass/temporal/c_libraries_interface.py
>>> line 19, in <module>
>>>     import grass.lib.gis as libgis
>>>   File "/usr/lib/grass70/etc/python/grass/lib/gis.py", line 23, in
>>> <module>
>>>     _libs["grass_gis.7.0.4"] = load_library("grass_gis.7.0.4")
>>>   File "/usr/lib/grass70/etc/python/grass/lib/ctypes_loader.py",
>>> line 55, in load_library
>>>     return self.load(path)
>>> line 71, in load
>>>     raise ImportError,e
>>> ImportError: libgrass_datetime.7.0.4.so: cannot open shared object
>>> file: No such file or directory
>>> Did I forgot to set-up something or this is a bug?
>>> Cheers,
>>> Laurent
>>> grass-dev mailing list
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
