[GRASS-dev] [GRASS GIS] #3165: v.out.ogr -c seg fault
GRASS GIS trac at osgeo.org
Thu Sep 22 05:09:15 PDT 2016
  Reporter:  ychemin  |      Owner:  grass-dev@…
      Type:  defect   |     Status:  new
  Priority:  normal   |  Milestone:  7.0.5
 Component:  Vector   |    Version:  svn-trunk
Resolution:           |   Keywords:  v.out.ogr
       CPU:  x86-64   |   Platform:  Linux
Comment (by mmetz):
 Replying to [comment:4 ychemin]:
 > ==9324== Memcheck, a memory error detector
 > ==9324== Copyright (C) 2002-2015, and GNU GPL'd, by Julian Seward et al.
 > ==9324== Using Valgrind-3.12.0.SVN and LibVEX; rerun with -h for
 copyright info
 > ==9324== Command: v.out.ogr -e -c input=indices type=area
 output=//home/yann/Desktop/watersheds/img1_4/out.shp layer=1
 format=ESRI_Shapefile --overwrite
 > ==9324==
 > WARNING: The map contains islands. With the -c flag, islands will appear
 as
 >          filled areas, not holes in the output map.
 > ==9324== Use of uninitialised value of size 8
 > ==9324==    at 0x507515D: Vect_get_centroid_area (level_two.c:440)
 > ==9324==    by 0x10DFBF: export_areas_single (export_areas.c:81)
 > ==9324==    by 0x10DFBF: export_areas (export_areas.c:33)
 > ==9324==    by 0x10CCC1: main (main.c:737)
 Thanks, fixed in r69546-8 (trunk, relbr72, relbr70).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3165#comment:5>
