[GRASS-dev] [GRASS GIS] #2848: g.gui.vdigit: snapping distance seems to only be defined in map units, not screen pixels
trac at osgeo.org
Mon Sep 26 08:18:07 PDT 2016
screen pixels
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.5
Component: wxGUI | Version: svn-releasebranch70
Resolution: | Keywords: vector, digitize
CPU: Unspecified | Platform: Unspecified
Comment (by annakrat):
Replying to [comment:9 mlennert]:
> Replying to [comment:8 annakrat]:
> > Replying to [comment:7 mlennert]:
> > > Replying to [comment:6 annakrat]:
> > > > Please test. It was only problem when using different locale.
> > > Right. It +/- works now, i.e. when I chose "screen pixels", I now
get the correct value in map units below. However, when I change the value
(i.e. the number of screen pixels), I get a wrong number below: the number
of screen pixels instead of map units. I have to switch to map units and
back to screen pixels for the depicted value in map units to be correct
again.
> > OK, I committed a new fix in r69579.
> Seems to work great, now ! Thanks.
> Not sure if this is mature enough to backport to release70. You're a
better judge of that.
The only problem is in the settings. The old value should be ignored and
then new value (0 or 1 is saved). You can test it by manually changing the
values in the settings file. Since you didn't report any problem with the
new patch I assume it ignores your saved settings value ("screen pixels"
or the french version), but please check, you should have now there 0 or 1
if you saved the settings.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2848#comment:10>
