[GRASS-dev] [GRASS GIS] #3167: db.connect: connection to remote database does not work
trac at osgeo.org
Tue Sep 27 00:02:46 PDT 2016
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.5
Component: Database | Version: unspecified
Resolution: | Keywords: postgresql db.connect
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
The issue arises when some of the fields are empty, as for usr and pwd in
my example. Anything from that point on is ignored. When I set a username
and password with db.login, my db.tables example works like a charm.
See [http://stackoverflow.com/questions/1508754/how-do-i-parse-out-the-
fields-in-a-comma-separated-string-using-sscanf-while-sup here] for a
discussion of the issue. Would using strtok be an alternative, here ? Or
better yet: G_tokenize() ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3167#comment:10>
