[GRASS-dev] [GRASS GIS] #3168: Behavior of t.register when r.timestamp was used
trac at osgeo.org
Tue Sep 27 11:40:00 PDT 2016
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.0
Component: Temporal | Version: svn-trunk
Resolution: | Keywords: t.create, t.register, r.timestamp,
CPU: | G_write_raster_timestamp
Unspecified | Platform: Unspecified
Comment (by huhabla):
This is indeed a strange error. I will fix the register method to use only
the time stamp from the spatial database, when no time stamp was provided
on the command line or in the input file.
One reason why this error happened is that r.sim.water creates a relative
time stamp and you specified an absolute time stamp on the command line.
Hence, the wrong time stamp conversion.
Interesting error case that i did not test.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3168#comment:1>
