[GRASS-dev] [GRASS GIS] #3166: Parallelization with tiling for grass.script
GRASS GIS trac at osgeo.org
Tue Sep 27 21:05:02 PDT 2016
  Reporter:  wenzeslaus   |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  normal       |  Milestone:  7.4.0
 Component:  Python       |    Version:  unspecified
Resolution:               |   Keywords:  script, parallel
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by wenzeslaus):
 Yes, I would like to reconcile the two APIs or implementations (or both).
 At this point, I still see too many differences.
 Replying to [comment:4 huhabla]:
 > IMHO, the for-loop to setup the processing commands for the
 TiledWorkflow can be avoided when using the PyGRASS Module and MultiModule
 approach.
 The API with for-loop is actually based on the case where the user wants
 the for loop like this one:
 #!python
 for i in range(0, 5):
     gs.run_command('r.module', num=i)
     gs.mapcalc(expr, num=i)
 I had code like this and I wanted to parallelize the individual loop runs
 which are independent. So I just come up with the following API which is
 not changing much in the main part of the code:
 #!python
 workflow = SeriesWorkflow()  # currently called ModuleCallList
     workflow.run_command('r.module', num=i)
     workflow.mapcalc(expr, num=i)
 workflow.execute()
 The Python functions I used in the background have some problems with
 interrupting and failed subprocesses but they handle well a pool of
 subprocess so that there is always the given number of processes running
 (so there can be one really slow process but the others are just running
 in the mean time).
 Then I had a different case, where I didn't have any loop but I needed the
 tiling. The following API emerged from that:
 #!python
 for namer, workflow in TiledWorkflow(width=100, height=100):
     name = namer.name('rast', i)
     workflow.run_command('r.module', num=name)
     workflow.mapcalc(expr, num=name)
 workflow.execute()
 This was of course before r69507, but the reasons for similar API are
 still there because the non-tiled workflow just has the loop anyway (if
 desired). One argument against current `TiledWorkflow` would actually be
 that we want the API to be different from the case where the loop is
 actually desired by the user.
 > The PyGRASS Module objects allows to alter the input and output settings
 before running, so that the TiledWorkflow class could take care of the
 tile names, altering the user pre-configured Module objects. The user
 simply initiates the Modules that should be used with the original raster
 names.
 The user (at least me) uses variables anyway. With the `SeriesWorkflow`
 case, user names the outputs as needed because all are preserved. With
 `TiledWorkflow` the variables needs to be assigned with the help of the
 `TiledWorkflow`, so some work is required but not that much.
 > The PyGRASS Module allows deep copy operation to clone the existing
 Module objects, hence the TiledWorkflow can create any number of copies
 and replacing the raster names with tile names.
 I don't think it is as simple as replacing the names which is of course
 possible only with PyGRASS, not grass.script. The naming step in
 `TiledWorkflow` simply adds maps for patching. This has potential to
 handle the case for r.mapcalc expressions as well as ''some'' basename
 usages like from r.texture. I don't have this implemented, but the user
 could also not include some outputs for patching and mark them for removal
 instead.
 > > The implementation is now 300 lines. MultiModule alone has 200
 > Well it is not much "Code". The doctests and the description of
 MultiModule are more than 100 lines. ;)
 Right. I guess my point is that parallel.py mostly relies on higher level
 functions from Python multiprocessing and on grass.script which is itself
 simple. Furthermore, parallel.py is more than just `TiledWorkflow`,
 although that's the longest and most complicated part. The parallel.py's
 design is to cover as many cases as possible with minimal code and the
 cost is that user needs to do something special time to time like the
 naming step for `TiledWorkflow` or the use of somehow wrapper functions
 instead of the real ones (applies to both `SeriesWorkflow` and
 `TiledWorkflow`). However, I think that `MultiModule` and others are much
 more robust at this point. parallel.py's only hope for being robust is
 that it is simple enough to become robust one day.
 I hope this clarifies a little bit more where I'm coming from. I know I
 was not specific in that private email week ago.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3166#comment:5>
