[GRASS-dev] [GRASS GIS] #3167: db.connect: connection to remote database does not work
trac at osgeo.org
Wed Sep 28 05:06:45 PDT 2016
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.5
Component: Database | Version: unspecified
Resolution: | Keywords: postgresql db.connect
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Another issue linked to the wxGUI (reported by Stefan Lüdtke - I can
confirm):
"If everything is in db.login, I can connect to the db (as reported
earlier) and list tables. However I can neither link nor import them
because they are not listed in the gui box."
I can see the database in the list, but once I select it, no tables are
listed.
Using
v.in.ogr input="PG:dbname=testgrass host=myRemoteServer"
layer=boundary_county out=bc
I can import a layer, but not using
v.in.ogr input="PG:dbname=testgrass" layer=boundary_county out=bc
I imagine v.in.ogr does not take into account the .grass7/dblogin file.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3167#comment:12>
