[GRASS-dev] [GRASS GIS] #3167: db.connect: connection to remote database does not work
trac at osgeo.org
Wed Sep 28 06:46:36 PDT 2016
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.5
Component: Database | Version: unspecified
Resolution: | Keywords: postgresql db.connect
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:12 mlennert]:
> Another issue linked to the wxGUI (reported by Stefan Lüdtke - I can
confirm):
> "If everything is in db.login, I can connect to the db (as reported
> earlier) and list tables. However I can neither link nor import them
> because they are not listed in the gui box."
> I can see the database in the list, but once I select it, no tables are
listed.
> Using
> v.in.ogr input="PG:dbname=testgrass host=myRemoteServer"
layer=boundary_county out=bc
> I can import a layer, but not using
> v.in.ogr input="PG:dbname=testgrass" layer=boundary_county out=bc
> I imagine v.in.ogr does not take into account the .grass7/dblogin file.
In grass70_release/vector/v.in.ogr/main.c, I see (line 359-60):
if (driver_name && strcmp(driver_name, "pg") == 0 &&
G_strcasecmp(param.dsn->answer, "PG:") == 0) {
Two questions:
* Why does the default driver have to be "pg", here ? We should import
from postgres, whatever the default driver.
* Unless I misunderstand how G_strcasecmp works,
G_strcasecmp(param.dsn->answer, "PG:") will never be 0 (it would be only
in the case that param.dsn->answer = 'PG:', but that should never be the
case). So, IIUC, the condition is never met and whatever we would like to
add to the dsn in terms of username, passwd, host, etc will never be
added.
If I skip the condition check (but obviously the 'PG:' check is needed),
and I add something like this to main.c:
--- main.c (révision 69596)
+++ main.c (copie de travail)
@@ -382,6 +382,10 @@
strcat(dsn, " passwd=");
strcat(dsn, conn.password);
+ if (conn.hostName) {
+ strcat(dsn, " host=");
+ strcat(dsn, conn.hostName);
/* TODO: host/port... */
else {
v.in.ogr imports a layer from the database on a remote server if the login
info is correct.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3167#comment:21>
