[GRASS-dev] [GRASS GIS] #3167: db.connect: connection to remote database does not work
trac at osgeo.org
Wed Sep 28 07:10:21 PDT 2016
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.5
Component: Database | Version: unspecified
Resolution: | Keywords: postgresql db.connect
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:25 martinl]:
> Replying to [comment:23 martinl]:
> > Thanks for testing, patch applied in all active branches
(r69597-r69599)
> What is missing to downgrade priority at least and don't block 7.0.5
release?
There is a fundamental issue about importing data from remote server using
v.in.ogr. See #comment:21 on part of the details. But looking into the
code, I see even more weirdness: for some reason, v.in.ogr only looks at
the default database of a pg db.connect-defined connection. I have no
idea, why. v.in.ogr should import whatever data is available, even from
other databases.
Example (after disabling the condition check mentioned above):
createdb -h myRemoteServer testgrass2
db.connect driver=pg database=testgrass2
db.login host=myRemoteHost
db.tables -p
Everything works, no tables shown. But then:
v.in.ogr input="PG:dbname=testgrass" layer=boundary_county out=bc
with testgrass defined in .grass7/dblogin as
pg|testgrass|||myRemoteServer|
I get (with DEBUG=1)
D1/1: G_set_program_name(): v.in.ogr
D1/1: Using dsn=PG:dbname=testgrass2 host=myRemoteServer
ERREUR :Layer <boundary_county> not available
D1/1: G_set_program_name(): g.gisenv
i.e. it automatically tries to get the table from testgrass2, not
testgrass.
This comes from the fact that the name of the database is read as such:
dbname = db_get_default_database_name();
Instead of trying to read the database from the dsn string...
In other words, it seems that importing data from a remote database in
v.in.ogr needs to be done using a complete dsn string, even if db.login
was called. And that this will only work on the command line, not in the
import wizard. Do you confirm ?
I guess we could call this a "known limitation" and just release as is, as
it would need a substantial rewrite which I would like to avoid just
before a release, but it is confusing to users. So maybe some hint about
this in the import wizard ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3167#comment:26>
