[GRASS-dev] [GRASS GIS] #3167: db.connect: connection to remote database does not work
GRASS GIS trac at osgeo.org
Wed Sep 28 09:50:24 PDT 2016
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  blocker      |  Milestone:  7.0.5
 Component:  Database     |    Version:  unspecified
Resolution:               |   Keywords:  postgresql db.connect
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mlennert):
 Replying to [comment:27 martinl]:
 > Replying to [comment:26 mlennert]:
 > > Example (after disabling the condition check mentioned above):
 > > createdb -h myRemoteServer testgrass2
 > > db.connect driver=pg database=testgrass2
 > > db.login host=myRemoteHost
 > > db.tables -p
 > > Everything works, no tables shown. But then:
 > OK, so it means that DB is empty, right?
 Yes, the database I want to use as attribute backend.
 > > D1/1: G_set_program_name(): v.in.ogr
 > > D1/1: Using dsn=PG:dbname=testgrass2 host=myRemoteServer
 > > ERREUR :Layer <boundary_county> not available
 > > D1/1: G_set_program_name(): g.gisenv
 > I do not understand - DB is empty, so why do you expect that `v.in.ogr`
 will not fail?
 Because my call to v.in.ogr was
 v.in.ogr input="PG:dbname=testgrass" layer=boundary_county out=bc
 i.e. trying to get a layer in db 'testgrass' and import it into my
 GISDBASE, storing the attributes into my database testgrass2. I.e. (as you
 note yourself in your next post here), v.in.ogr without a complete dsn
 string (i.e. containing host, etc) will try to connect to the current
 default attribute backend database, not the one you actually provide on
 the command line.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3167#comment:29>
