[GRASS-dev] [GRASS GIS] #2445: r.mask -r removal not working in GRASS 7.1 svn r.62210
GRASS GIS trac at osgeo.org
Thu Sep 29 01:01:22 PDT 2016
  Reporter:  baharmon     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.2.0
 Component:  Raster       |    Version:  svn-trunk
Resolution:               |   Keywords:  r.mask
       CPU:  Unspecified  |   Platform:  MSWindows 8
Comment (by mlennert):
 Replying to [comment:10 sbl]:
 > Confirmed on Win7.
 > g.remove type=rast pattern=MASK -f does not remove a map "mask" on
 Windows, while
 > g.remove -fi type=rast pattern=MASK does.
 Ok. I've attached a patch that AFAICT should check for Windows and then
 make the g.remove call case insensitive.
 Please test.
 Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2445#comment:11>
