[GRASS-dev] [GRASS GIS] #2627: v.out.postgis uses wrong database name or port
trac at osgeo.org
Thu Sep 29 01:15:23 PDT 2016
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.0
Component: Default | Version: svn-trunk
Resolution: | Keywords: PostgreSQL, postgres, PostGIS
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
The handling of host and port info have changed (use db.login instead of
db.connect for that info). Could you test whether this is still an issue
for you in 7.2 ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2627#comment:2>
