[GRASS-dev] [GRASS GIS] #3198: r.stats.quantile: hardcoded max number of categries in base map
GRASS GIS trac at osgeo.org
Wed Apr 5 08:11:50 PDT 2017
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  closed
  Priority:  normal       |  Milestone:  7.2.1
 Component:  Raster       |    Version:  unspecified
Resolution:  fixed        |   Keywords:  r.stats.quantile MAX_CATS
       CPU:  Unspecified  |   Platform:  Unspecified
Changes (by mlennert):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 Closing this as the original issue seems to be fixed. As the solution is
 not a simple bug fix, it should probably not go into 7.2.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3198#comment:4>
