[GRASS-dev] problem building 7.2.1RC1 for UbuntuGIS
Sebastiaan Couwenberg
sebastic at xs4all.nl
Sat Apr 8 09:42:20 PDT 2017
On 04/08/2017 06:21 PM, Martin Landa wrote:
> 2017-04-08 14:06 GMT+02:00 Sebastiaan Couwenberg <sebastic at xs4all.nl>:
>> None of the objects files have a main() function, which makes sense for
>> a library. It may be related to PIE, you can try building without it.
> yes, but it's strange that we didn't have any problem when building
> 7.2.0 release...
PIE was disabled then, it was (re-)enabled in 7.2.0-2 now that gcc is
fixed in Debian to handle it properly, see:
https://anonscm.debian.org/cgit/pkg-grass/grass.git/commit/?id=f7d83e8407e477aa77177b5744ece30fed7327d0
https://bugs.debian.org/859372
Ubuntu likely doesn't have these changes yet in releases pre-zesty,
making PIE still problematic there.
If you can confirm that disabling PIE fixes the issue, we can make the
hardening flags conditional and disabled them on Ubuntu.
Kind Regards,
Bas
GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146 50D1 6750 F10A E88D 4AF1
