[GRASS-dev] problem building 7.2.1RC1 for UbuntuGIS
Sebastiaan Couwenberg sebastic at xs4all.nl
Sun Apr 9 04:14:08 PDT 2017
On 04/09/2017 01:07 PM, Martin Landa wrote:
> 2017-04-08 18:42 GMT+02:00 Sebastiaan Couwenberg <sebastic at xs4all.nl>:
>> PIE was disabled then, it was (re-)enabled in 7.2.0-2 now that gcc is
>> fixed in Debian to handle it properly, see:
>>  https://anonscm.debian.org/cgit/pkg-grass/grass.git/commit/?id=f7d83e8407e477aa77177b5744ece30fed7327d0
>>  https://bugs.debian.org/859372
>> Ubuntu likely doesn't have these changes yet in releases pre-zesty,
>> making PIE still problematic there.
>> If you can confirm that disabling PIE fixes the issue, we can make the
>> hardening flags conditional and disabled them on Ubuntu.
> thanks for explanation! Disabling PIE helped [1]. Thanks, Martin
I've updated debian/rules to disable PIE on Ubuntu, see:
 https://anonscm.debian.org/cgit/pkg-grass/grass.git/commit/?h=experimental&id=1b6b075ecfdd703e2dad5c309860f86856190b05
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
