[GRASS-dev] r.fill.gaps porting
Markus Neteler
neteler at osgeo.org
Sat Apr 15 09:26:27 PDT 2017
On Apr 15, 2017 5:47 PM, "Maris Nartiss" <maris.gis at gmail.com> wrote:
> It is correct as it resizes the width not height of image. There is a
> wrong assumption that setting width automatically should set also
> height. Not according to HTML spec (proportional scaling is not
> mandated). Thus wxPython HTML renderer correctly sets height=100% and
> width=600px. I changed submitting guidelines in Trac. Now it is
> necessary to provide correct heights for all images that have a width
> parameter.
Ok thanks for the update.
Ideally all manual pages would be updated to the same standard.
Anyone good in regex? Otherwise I could try a semi-manual bulk editing.
Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170415/2cfeab9a/attachment.html>
