[GRASS-dev] [GRASS GIS] #3334: d.legend.vect - symbols missing
GRASS GIS trac at osgeo.org
Mon Apr 17 08:07:54 PDT 2017
 Reporter:  pvanbosgeo   |      Owner:  grass-dev@…
     Type:  defect       |     Status:  new
 Priority:  normal       |  Milestone:  7.2.1
Component:  Default      |    Version:  unspecified
 Keywords:               |        CPU:  Unspecified
 Platform:  Unspecified  |
 When trying to save a map with legend as png file, the legend symbols are
 missing. E.g., I have a vector map with a column RGBcolor with the RGB
 colors, and a legend file 'legendfile' (see attached):
 d.frame -c frame=map1 at="0,100,30,100"
 d.vect map=WakeMunicp rgb_column=RGBcolor
 d.frame -c frame=map2 at="0,100,0,29"
 d.legend.vect -b at="2,95" title=Municipals input=legendfile
 d.mon stop=png
 The legend symbols are showing, on the other hand, when sending the map to
 wx monitor.
 d.mon start=wx0
 d.legend.vect -b at="2,95" title=Municipals input=tmplegendfile
 d.mon stop=png
Ticket URL: <https://trac.osgeo.org/grass/ticket/3334>
