[GRASS-dev] Fwd: [wxPython-users] wxPython 4.0.0a1
Martin Landa
landa.martin at gmail.com
Tue Apr 18 04:16:53 PDT 2017
fyi. Especially wxGUI devs could be interested. Ma
---------- Forwarded message ----------
Date: 2017-04-18 2:55 GMT+02:00
Subject: [wxPython-users] wxPython 4.0.0a1
To: wxpython-users at googlegroups.com, wx-users at googlegroups.com,
wx-announce at googlegroups.com, Python-Announce-List at python.org
Announcing wxPython 4.0.0a1
https://pypi.python.org/pypi/wxPython/4.0.0a1
I'm pleased to announce that wxPython's Project Phoenix has made it's public
debut as wxPython 4.0.0a1, available from PyPI. Don't let the fact that it is
marked as an "alpha" release scare you away. It is an alpha simply because
this is the **first** in several ways:
* It's the first real release of Phoenix, which is built on a different
foundation than Classic wxPython was.
* It's the first wxPython release intended to be fully available from PyPI and
buildable/installable by pip on all of the supported platforms.
* It's the first release for Python3 (binaries for 3.5 and 3.6 are provided,
and building for 3.4 is still possible as well). In addition, Python 2.7
is also supported from the same codebase, with binaries available.
* The wheel files are fully self-contained and relocatable on the supported
platforms, so they are installable in virtual environments without needing
to be able to find specific versions of the wxWidgets shared libraries
(or others) at fixed locations elsewhere in the file-system.
* And as with most alphas, there are still a few things that are not
finished or polished yet.
But even with all that, many people have been using the pre-release snapshots
of Phoenix for quite a while now, and it has been relatively stable and solid
for them.
What is wxPython?
wxPython is a cross-platform GUI toolkit for the Python programming language.
It allows Python programmers to create programs with a robust, highly
functional graphical user interface, simply and easily. It is implemented as a
set of Python extension modules that wrap the GUI components of the popular
wxWidgets cross platform library, which is written in C++. Supported platforms
are Microsoft Windows, Mac OS X and macOS, and Linux or other unix-like
systems with GTK2 or GTK3 libraries. In most cases the native widgets are used
on each platform to provide a 100% native look and feel for the application.
What is wxPython Phoenix?
wxPython's Project Phoenix is a new from-the-ground-up implementation of
wxPython, created with the intent of making wxPython “better, stronger, faster
than he was before.” In other words, this new implementation is focused on
improving speed, maintainability and extensibility of wxPython, as well as
removing most of the cruft that had accumulated over the long life of Classic
wxPython.
The project has been in development off and on, mostly behind the scenes, for
many years. For the past few years automated snapshot builds have been
available for those adventurous enough to try it, and many people eventually
started using the snapshots in their projects, even for production releases.
While there are still some things on the periphery that need to be completed,
the core of the new wxPython extension modules which wrap the wxWidgets code
has been stable for a long time now.
Due to some things being cleaned up, reorganized, simplified and dehackified
wxPython Phoenix is not completely backwards compatible with wxPython Classic.
This is intended. In general, however, the API differences tend to be minor
and some applications can use Phoenix with slight, or even no modifications.
In some other cases the correct way to do things was also available in Classic
and it's only the wrong way that has been removed from Phoenix. For more
information there is a Migration Guide document available at:
https://wxpython.org/Phoenix/docs/html/MigrationGuide.html
The new wxPython API reference documentation, including all Python-specific
additions and customizations, and docs for the wx.lib package, is located at:
https://wxpython.org/Phoenix/docs/html/main.html
Robin Dunn
Software Craftsman
http://wxPython.org
You received this message because you are subscribed to the Google
Groups "wxPython-users" group.
To unsubscribe from this group and stop receiving emails from it, send
an email to wxpython-users+unsubscribe at googlegroups.com.
For more options, visit https://groups.google.com/d/optout.
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
