[GRASS-dev] [GRASS GIS] #3336: r.viewshed max_distance always in meters
trac at osgeo.org
Wed Apr 19 08:19:48 PDT 2017
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: Raster | Version: svn-trunk
Resolution: | Keywords: viewshed, units
CPU: All | Platform: All
Comment (by annakrat):
Replying to [comment:3 pvanbosgeo]:
> Replying to [comment:2 annakrat]:
> > Replying to [comment:1 pvanbosgeo]:
> > > If opting for the second option, I would suggest, if possible, to
include the option to set value in meters as well, or more in general, to
include the option to set the unit.
> > I don't think that's necessary here, ideally max_distance should be in
the map units, that's what everybody would expect, setting specific units
just for max_distance doesn't add much to the usability in my opinion.
> Can r.viewshed be run in latlon? In that case, being able to set the
maximum distance in meters could make sense?
I believe so, in latlon it uses meters, so that should be clarified in the
manual.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3336#comment:4>
