[GRASS-dev] [GRASS GIS] #3335: v.to.rast with label_column set results in raster with part of raster cells without label
trac at osgeo.org
Wed Apr 19 13:13:47 PDT 2017
without label
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.1
Component: Default | Version: unspecified
Resolution: | Keywords:
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [ticket:3335 pvanbosgeo]:
The problem appears when a label is assigned to a range of values, e.g.
992:996:Morrisville
this means that all raster values from 992 to 996 should get the same
label "Morrisville". The raster library supports writing such a range of
values for all map types with Rast_set_cat(), but reading such a range of
values is supported only for fp maps (FCELL, DCELL).
Please try trunk r70900.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3335#comment:1>
