[GRASS-dev] [GRASS GIS] #3335: v.to.rast with label_column set results in raster with part of raster cells without label
GRASS GIS trac at osgeo.org
Thu Apr 20 06:09:02 PDT 2017
without label
  Reporter:  pvanbosgeo   |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.2.1
 Component:  Default      |    Version:  unspecified
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mmetz):
 Replying to [comment:2 pvanbosgeo]:
 > Replying to [comment:1 mmetz]:
 > > Replying to [ticket:3335 pvanbosgeo]:
 > > The problem appears when a label is assigned to a range of values,
 e.g.
 > > 992:996:Morrisville
 > > this means that all raster values from 992 to 996 should get the same
 label "Morrisville". The raster library supports writing such a range of
 values for all map types with Rast_set_cat(), but reading such a range of
 values is supported only for fp maps (FCELL, DCELL).
 > > Please try trunk r70900.
 > Quick try, seems to work now, thanks. So this means it now works for
 integer maps as well?
 Yes, getting a label for a range of values now works for CELL maps as well
 (setting a label for a range of values was already possible).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3335#comment:3>
