[GRASS-dev] [GRASS GIS] #2055: r.in.gdal lacks flag "-r Limit import to the current region"
trac at osgeo.org
Thu Apr 20 10:46:12 PDT 2017
Reporter: neteler | Owner: martinl
Type: enhancement | Status: assigned
Priority: normal | Milestone: 7.2.1
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.in.gdal, r.import
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [comment:28 martinl]:
> Replying to [comment:27 neteler]:
> > Replying to [comment:26 mmetz]:
> > > The patch attachment:r.in.gdal_region.patch limits import to the
current region and does lat/lon wrapping. The patch is automatically doing
region cropping (like r.proj), i.e. only the part overlapping with the
current region is imported. The patch uses window mapping equivalent to
the raster lib.
> > Thanks! Do you plan to submit this to trunk? This would facilitate
testing.
> yes, +1 for submitting to trunk
The patch needs some refinement with regard to nodata handling (I'm busy
with it), then it can be submitted to trunk.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2055#comment:29>
