[GRASS-dev] [release] GRASS 7.2.1RC2
Markus Neteler
neteler at osgeo.org
Sat Apr 22 06:44:56 PDT 2017
On Sat, Apr 22, 2017 at 9:13 AM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> On 20 April 2017 at 19:12, Markus Neteler <neteler at osgeo.org> wrote:
>> While generally yes, we still lack the po files update from transifex...
> The problem right now is the Portuguese translations files, mods an
> libs po file return a lot of "invalid multibyte sequence"
Fixed. The file simply needed to be converted to UTF-8 from ISO-8859-1
using iconv + editing of the header:
for i in `ls grass*_pt.po ` ; do iconv -f ISO-8859-1 -t UTF-8 $i >
dd.tmp ; \mv dd.tmp $i ; done
... then edit all three files for the header update of encoding.
No more "invalid multibyte sequence" errors.
Perhaps we should convert all .po files to UTF-8? This is not yet the case.
Additional observations:
- the transifex_merge.sh deletes all headers along with the translation authors
- it empties all "fuzzy" state messages.
Due to that I didn't merge yet the updated translations. I try to
understand where the header replacement with the generic gettext
header happens.
Markus
