[GRASS-dev] wxGUI unusual high CPU usage debugging
Markus Neteler neteler at osgeo.org
Tue Apr 25 03:38:37 PDT 2017
in order to address the issue that wxGUI (incl. d.mon wx0) causes high
CPU load when on wxGTK3,
the Fedora wxGTK3 would like to know how to debug the wxGUI with gdb.
I only found:
https://grasswiki.osgeo.org/wiki/GRASS_Debugging#wxPython_GUI_debugging
Any other pointers I could send to him?
thanks,
Markus
On Tue, Apr 25, 2017 at 6:26 AM, Markus Neteler  wrote:
> ---------- Forwarded message ----------
> From: <bugzilla at redhat.com>
> Date: Apr 25, 2017 6:16 AM
> Subject: [Bug 1440434] Unusual high CPU usage
> To: <neteler at gmail.com>
> Cc:
> https://bugzilla.redhat.com/show_bug.cgi?id=1440434
> --- Comment #3 from Scott Talbert <swt at techie.net> ---
> I don't think the problem with the Calendar demo is the same problem.  It
> could
> be, but I don't think it is at the moment.
> Can you help me figure out how I can run the g.gui under gdb?  If you can
> figure out the actual python program that it runs, that would be helpful.  I
> think I've had this same problem before when trying to look into these types
> of problems.  :-)
> You are receiving this mail because:
> You reported the bug.
