[GRASS-dev] [GRASS GIS] #3338: UnicodeDecodeError when registering maps in a STRDS using a translated version of GRASS
trac at osgeo.org
Tue Apr 25 15:11:39 PDT 2017
version of GRASS
Reporter: lrntct | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: Temporal | Version: 7.2.0
Keywords: translation UnicodeDecodeError | CPU: x86-64
Platform: Linux |
Using a Spanish locale, the following error appears when trying to
register maps in a STRDS using the python interface:
Registrando mapas en conjunto de datos espacio temporales...
Actualizando conjunto de datos temporales...
File "Documentos/tarea_6_5_Roberta.py", line 131, in <module>
sys.exit(main())
File "Documentos/tarea_6_5_Roberta.py", line 79, in main
register_maps_in_strds(TITULO_STRDS, ID_STRDS, DESC_STRDS,
list_nombre_fecha)
File "Documentos/tarea_6_5_Roberta.py", line 98, in
tgis.register.register_map_object_list('raster', map_dts_lst, stds,
delete_empty=True, unit=None)
File "/usr/lib/grass72/etc/python/grass/temporal/register.py", line 499,
in register_map_object_list
file=filename, dbif=dbif)
File "/usr/lib/grass72/etc/python/grass/temporal/register.py", line 341,
in register_maps_in_space_time_dataset
sp.update_from_registered_maps(dbif)
File
"/usr/lib/grass72/etc/python/grass/temporal/abstract_space_time_dataset.py",
line 2282, in update_from_registered_maps
" all registered maps of <%s>") % (self.get_id()))
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 28:
ordinal not in range(128)
Changing the system settings to English fix the issue.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3338>
