[GRASS-dev] [GRASS GIS] #3339: postgis topology: missing relations
trac at osgeo.org
Fri Apr 28 05:30:17 PDT 2017
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.1
Component: LibVector | Version: unspecified
Keywords: postgis topology | CPU: Unspecified
Platform: Unspecified |
GRASS currently wrongly interprets relation between feature table and
topological primitives (nodes, edges, faces). The correct relation is
defined by `relation` table in topo schema which is currently empty.
test=# SELECT * from topo_sample_invalid_geom_in_pg.relation;
topogeo_id | layer_id | element_id | element_type
(0 rows)
Correct table for 3 polygons:
test=# SELECT * from topo_sample_invalid_geom_in_pg1.relation;
1 | 1 | 1 | 3
2 | 1 | 2 | 3
3 | 1 | 30 | 3
(3 rows)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3339>
