[GRASS-dev] [GRASS GIS] #3340: wxGUI: encoding error when saving a workspace with vector that has accents in legend_label
GRASS GIS trac at osgeo.org
Fri Apr 28 08:12:25 PDT 2017
in legend_label
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.2.2
 Component:  wxGUI        |    Version:  svn-trunk
Resolution:               |   Keywords:  legend_label workspace
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mlennert):
 Replying to [comment:1 annakrat]:
 > In [changeset:"70979" 70979]:
 > #!CommitTicketReference repository="" revision="70979"
 > wxGUI: fix encoding, see #3340
 Works great. Thanks for the quick fix !
 You changed the milestone to 7.2.2. I had the feeling that this is a quite
 small and pretty non-invasive fix of a standard bug. Don't you think it
 could still go into 7.2.1 ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3340#comment:3>
