[GRASS-dev] [GRASS GIS] #3387: r.to.vect fails on a properly thinned tif via r.thin/r.null
trac at osgeo.org
Thu Aug 3 11:51:23 PDT 2017
Reporter: hbgdal | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: Raster | Version: 7.2.0
Resolution: | Keywords: r.to.vect
CPU: Unspecified | Platform: Linux
Description changed by martinl:
Old description:
> Hi, This happens only on a small number of tif files. Most of the tif
> files are processed successfully. Commands to reproduce problem with
> 7.2.0 are pasted below. I would appreciate any workaround/patch(for 7.2.0
> or any other version) for this fix.
> Problem:
> For some tifs, the r.to.vect fails complaining that the image needs to be
> thinned, and then hangs with a message about busy SQLite DB.
> Expected behavior:
> Either r.to.vect should extract lines from thinned image, or r.thin
> should thin the image further.
> Env:
> Ubuntu 14.04. 7.2.0 compiled
> Commands to run:
> #This is "binary" image with two colors black and white
> r.in.gdal input=/tmp/grass_problem.tif output=grass_problem
> location=grass_problem
> #Replace "white" color with null for r.thin.
> r.null --verbose map=grass_problem at PERMANENT setnull=255
> #r.thin succeeds in less than 10 iterations.(See output below)
> r.thin --verbose input=grass_problem at PERMANENT output=grass_thin
> #r.to.vect complains.
> r.to.vect --verbose input=grass_thin at PERMANENT output=vec_lines type=line
> ===== r.thin output showing success ====
> Raster map <grass_problem at PERMANENT> - 4028 rows X 3288 columns
> Bounding box: l = 3, r = 3284, t = 7, b = 4028
> Pass number 1
> Deleted 240415 pixels
> Pass number 2
> Deleted 5154 pixels
> Pass number 3
> Deleted 115 pixels
> Pass number 4
> Deleted 5 pixels
> Pass number 5
> Deleted 0 pixels
> Thinning completed successfully.
> Output map 4028 rows X 3288 columns
> Window 4028 rows X 3288 columns
> (Thu Aug 3 11:17:10 2017) Command finished (2 sec)
> === r.to.vect output showing failure ===
> Using native format
> Extracting lines...
> Crowded cell at (362.125000, 12883.540000): row 424, col 1721, count 7
> ERROR: Raster map is not thinned properly.
> Please run r.thin.
> WARNING: Busy SQLITE db, already waiting for 10 seconds.
New description:
files are processed successfully. Commands to reproduce problem with 7.2.0
are pasted below. I would appreciate any workaround/patch(for 7.2.0 or any
Problem:
Expected behavior:
Either r.to.vect should extract lines from thinned image, or r.thin should
Env:
Commands to run:
Pass number 1
Pass number 2
Deleted 5154 pixels
Pass number 3
Deleted 115 pixels
Pass number 4
Deleted 5 pixels
Pass number 5
Deleted 0 pixels
Using native format
Extracting lines...
Please run r.thin.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3387#comment:2>
