[GRASS-dev] New attempt to update GRASS for Mac
Moritz Lennert
mlennert at club.worldonline.be
Thu Aug 3 23:56:02 PDT 2017
On 04/08/17 00:33, Vaclav Petras wrote:
> Well, the error (below) suggests that wrong library is either linked or
> included. You need to go through the -L and -I paths and see if you need
> to set one of these differently or add additional one for iconv. I don't
> see how to set this through ./configure (I don't see any
> --with-iconv-includes= or --with-iconv-libs=), but you can start by
> editing the Makefiles or the command itself and changing -L and -I directly.
> Undefined symbols for architecture x86_64:
> "_iconv", referenced from:
> _draw_main in text3.o
> "_iconv_close", referenced from:
> "_iconv_open", referenced from:
> ld: symbol(s) not found for architecture x86_64
> clang: error: linker command failed with exit code 1 (use -v to see
> invocation)
Just guessing: Could the error be linked to the use of clang ? Have you
tried with gcc ?
Moritz
